pulling trans and intake this weekend?? - Page 2 - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 5.0L (1979-1995) Mustang
Reload this Page >
Old 09-07-2007, 10:15 AM
blk40th
Default RE: pulling trans and intake this weekend??
y is that? should i not bother replacing it?
blk40th is offline
Old 09-07-2007, 10:32 AM
WhiteWindsor
Sometimes it is just hit or miss. It should not leak when replacing it as long as it is done right. I have never had one leak, but know many people that have. I have a new one piece rear main seal in mine now that is leaking. I had my 351 block machined to a one piece seal because the two piece seal broke loose and was leaking like a seive. I could take it back to machine shop but it is only a small leak and it is not worth taking engine out now. They install the seal, and they told me next time i take engine out they will check the machine work to make sure everything is true.
WhiteWindsor is offline
Old 09-07-2007, 10:54 AM
1991LX5.0
I would consider buying a new flywheel if its apenny over $30. When i was looking to have mine turned the lowest i could find was like $45 so i bought a new ford racing one from a local shop for $95 and i sold my old used one on ebay for $61. I couldnt believe people would pay that much for a used flywheel
1991LX5.0 is offline
Old 09-07-2007, 11:32 AM
blk40th
yea i mean ive installed rear mains before so i should be ok. yea ill have to even see if the flywheel is bad. im sure it is though cuz the chatter is bad. i just went to autozone and ordered the pilot bearing and a cheap clutch disc. i just want to do this to hold me over until i can get the tko600 and spec stage 2.
blk40th is offline
Old 09-07-2007, 11:53 AM
blk40th
how hard is it to put the trans all back in without the alignment tool?
blk40th is offline
Old 09-07-2007, 01:26 PM
aode08
ORIGINAL: blk40th
dont make your day harder than it has to be, you can rent that and the pilot bearing puller and attachment for free at Autozone.
Replace the rear main seal, coat the new one with bearing greese and smack it soft and EVEN till it will not go back. keep notice of the side with the spring and the side without.
IT WILL NOT LEAK
aode08 is offline
Old 09-07-2007, 01:30 PM
aode08
you cant go wrong man to mess something this simple up
aode08 is offline
Old 09-07-2007, 02:08 PM
blk40th
lol yea i know thats what i thought. if anything i was always taught that if i get a socket or something that is the same diameter then use that and tap it slowly. i appreciate the help from everyone.
blk40th is offline
Old 09-07-2007, 03:31 PM
gspfunk
gspfunk's Avatar
I just used some bearing grease, packed it in behind the existing pilot bearing, and then (like you mentioned) used a socket and an extension in front of a hammer...it comes right out. Make sure the socket is a tight fit in the center of the pilot bearing.
Also, lube up the outside of the new one before you put it in and it will go in a LOT easier.
gspfunk is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
PullTab
10-30-2015 08:46 AM
97SN95GT
09-13-2015 09:45 PM
Pyrate Dave
09-10-2015 07:30 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Featured Sponsors
