Driveshaft
Driveshaft
How in the world do you break those bolts? They are prolly the tightest bolt ever, ive been spraying them with liquid wrench alot, got the whole car jacked up to get to them, have my friend hold the brake to reduce play and i still cant get them to budge...any help?
RE: Driveshaft
i used a 18 inch breaker bar....no good. i ended up using a 24 inch breaker bar and it worked (still having to muscle it off) the first time i took them off no problems. but this last time year....24 inch breaker bar is what you need
RE: Driveshaft
heat that b##ch up till shes almost chery then hit her with some pb blast repeat this once or twice shell come righ loose just be carefull of rubber seals and maybe bring some water with you grease fires suck!
RE: Driveshaft
ORIGINAL: big ben
RE: Driveshaft
The bolts need some impact action.
If you can't get an impact on there. Get back to the long breaker bar and smash the bar about 12 or 18" away from the socket. The shocking action should get it going.
