Typhoon intake question?
I will be installing a Typhoon upper/lower combo soon and wanted to know were to run vac. lines. The Typhoon has a different vac port set-up than stock, will I still be able to use that stock, black,triple vac, fitting that is mountedto the bottom ofthe stock intake? There is only one threaded 3/8"threaded port on the bottom of the Typhoon and there are three ports (1-3/8" and 2-5/16th) on the firewall side of the upper, can I just connect wherever is easiest? If anyone hasthis intake ,canyou post some pics? that would be great. I know alot of people don't like the Typhoon, but I got mine w/ports cleaned up for cheap, so I'll give it a shot.
RE: Typhoon intake question?
Sorry, it's a 93GT.
