HELP
Old 09-07-2007, 02:16 PM
5.0buildnherup
5.0buildnherup's Avatar
Default HELP
Alright guy's i need some help and bad . i have a 89 lincoln mark vii with the 5.0ho 302 in it. i have a really bad anti freeze i mean real bad like it leaks out real bad it look's like its coming down from the lower hose but i just replaced that yesterday and the top hose is also brand new. only thing i can thinnk is the water pump. but im not sure someone please help i need my car for work in a couple days.
5.0buildnherup is offline
Old 09-07-2007, 03:03 PM
93five0
93five0's Avatar
Default RE: HELP
Is the car overheating?
93five0 is offline
Old 09-07-2007, 03:30 PM
stangsta95
stangsta95's Avatar
Default RE: HELP
Drain plug tight?haha just kidding make sure everything is clamped right id look at the water pump as u were stating to good luck
stangsta95 is offline
Old 09-08-2007, 02:00 AM
5.0buildnherup
Default RE: HELP
Well guy's took the new lower hose off completley and tightned the clamps down better my fault. but ran it and once again does same thing only thing i can think is the water pump . which i just bought a bosch one from pep boys $30 with a lifetime warranty im just hoping its that if not im lost and not sure where to go from there:-/
Old 09-08-2007, 02:04 AM
Maxwelhse
Maxwelhse's Avatar
Default RE: HELP
On a long shot... Have you checked the little L shaped bypass hose on the top side of the water pump?
Maxwelhse is offline
Old 09-10-2007, 01:11 AM
5.0buildnherup
Default RE: HELP
Well guy's switched out the water pump got that brand new one and two new heater hoses the top and bottom tightned it all up ran her and no leaking *knock on wood so far*.
