Fuel Pressure??
Fuel Pressure??
Does anyone know if my 87 GT has an adjustable fuel pressure regulator? Either way, how do you check the fuel pressure and what should it be at (I'm stock).
Also, could arough idle be caused by by improper pressure? Am I correct in saying that the pressure is only made by the fuel pump and the regulator only controlls how much pressure goes by?
RE: Fuel Pressure??
No
With FP gauge hooked up to the schrader valve (bike tire valve looking thing) on your fuel rail
38 lbs or around there
Yes
Sort of...that's probably a good way to look at it (the reg doesn't make pressure, but keeps it AT something...the rest over that number bypasses and goes back into the fuel tank)
Yes
RE: Fuel Pressure??
ORIGINAL: tiburon
how could the FPR cause a rough idle? Would this just mean that the fuel pump is bad?It has a slight hum to it...
You can also check the vacuum line for any fuel or see if you smell fuel in the vacuum line to teh regulator. This, of course, is done with the car turned off
mrappe
09-26-2015 10:16 AM
