347 with a9 ecu?
i was wondering how much a 347 would in mess with the factory computer? i understand that the a9 series ecu's can handle a certain percentage of change before it starts acting up. i was just wondering if anyone has this setup, and what they have done.
RE: 347 with a9 ecu?
youll be fine
a9m,p or t will work better that a a9s(california emmisions reduction ecm)
you mean you can run a stroker motor with a factor ecu? i thought the ecu knew the engine displacement for calculating load stuff.
ORIGINAL: dillon1340 you mean you can run a stroker motor with a factor ecu? i thought the ecu knew the engine displacement for calculating load stuff. |
you shouldnt have a problem you'll want a tune on that new engine though
