E cam PTV clearance issues?????
Old 03-11-2009, 08:20 PM
1995mustang818
1995mustang818's Avatar
Default E cam PTV clearance issues?????
i put my cam in today but i have PTV clearance issues i took the spark plugs out just to make sure i didnt have any clearance issues and it spun about a 1/4 turn and it wouldnt let me go any more i loosed the rockers and only the intake valves are hitting the exhaust valves are fine i still have stock rockers and push rods . i was wondering maybe i didnt some thing wrong just how the stock cam came out i put in the E cam in the same position
1995mustang818 is offline
Old 03-11-2009, 08:35 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
now for ots purposes and not having a degree wheel, lets say before removal did you line the cam gears up dot to dot?? and vise versa for install of new cam,, e-cam with stock valvetrain hardware and stock valves should pose no ptv issues, I have an f-cam with such and no issues whatsoever
mjr46 is offline
Old 03-11-2009, 09:11 PM
1995mustang818
oh ok i didnt know about the lining up the 2 dots anything else i need to know ????or anything else i need to do ?
Old 03-11-2009, 09:24 PM
AdderMk2
Banned
AdderMk2's Avatar
OMFG!!!
things you need to know: The number of a good mechanic
Things you need to do:
Call a tow truck
Bring car to mechanic
Sell car once running
Buy a honda (because I dont give a rats *** if you **** that up)
AdderMk2 is offline
Old 03-11-2009, 09:29 PM
1995mustang818
stop being a ****in dick and help me out bro ive done a bunch of stuff on my stang head and intake swap but never done a cam...im preatty sure you werent born doing ****in cam swaps so relax and explain to me wat needs to be done how hard is that
Old 03-11-2009, 09:36 PM
OnyxCobra
OnyxCobra's Avatar
lmfao, that's sad but true.
cam swaps are incredibly easy, if you don't know you need to line up the dots then you shouldn't be working on your engine.
OnyxCobra is offline
Old 03-11-2009, 09:50 PM
mjr46
mjr46's Avatar
AS long as you haven't used the starter and just rolled the motor over by hand your not screwed yet............best thing to do is unbolt all the rockers roll the motor over so number 1 piston is up on tdc and keyway is straight up then roll the cam gear over so the dot is facing the bottom and the dot on the crank gear line up with it, then roll motor over twice and see if dots line back up at tdc then install rockers and roll back over and see if you feel it bind, setting motor on tdc is critical and making sure dot to dot is dead on or cam timing will be off and could seriously affect performance and or damage motor.
mjr46 is offline
Old 03-11-2009, 09:52 PM
AdderMk2
Banned
AdderMk2's Avatar
I forgot to add one thing
go buy a repair manual... and READ it
AdderMk2 is offline
Old 03-11-2009, 09:58 PM
1995mustang818
thanx mjr46 you gave me some preatty good forward instructions ill let you know how it goes tommorrow morning
Old 03-11-2009, 10:09 PM
mjr46
mjr46's Avatar
mine are just general concepts not a complete set of instructions, it'd you good to follow ADDERMK2'S advice on the repair manual or google cam install on ford 302
mjr46 is offline
Quick Reply: E cam PTV clearance issues?????
