afr heads
RE: afr heads
ORIGINAL: r.barn
AFR 165's
58cc chamber
1.6 rockers - stud mount.
AFR 165's
58cc chamber
RE: afr heads
ORIGINAL: 1fastzook
I agree.Thats what i would go with.Imo stud mount is way easier to adjust.As for the cam its already in there,iwould leave it alone.
ORIGINAL: r.barn
AFR 165's
58cc chamber
AFR 165's
58cc chamber
RE: afr heads
I'm running the 165 with pedestal mount. All I needed were longer pushrods(I changed everything but the block so that was bound to happen). 165's are great for a street 302. 185's would be better for a stroker or a blown application, or something with a big cam. 165's even n/a are capable of putting outvery goodpower from a 302
RE: afr heads
ORIGINAL: Gary H
If you have the stock 86 pistons be carefull on the cam you choose. They dont have notches in them for the valves.
RE: afr heads
you might have a piston clearance problem with the afr 185's. read the thread above. i'veheard ofpeople running the 2.02 heads and didn't have any problems with stock piston clearance. the only 2.02 head that was made to run withoutnotching the pistonis the twisted and wedge head. i believe thats what made them so popular on the stock 302 motor. however, if you don't want any problems stick with the afr 165's. they are one of the best out the box heads.
