ALUMINUM RADIATOR AND PRESTONE RAD FLUSH
DOES ANYONE KNOW IF THE RRESTONE RADIATOR FLUSH IS OK TO FLUSH A 2 YR OLD FLUIDYNE RADIATOR WITH?
RE: ALUMINUM RADIATOR AND PRESTONE RAD FLUSH
as long as it says on there aluminum safe. then yes its ok
That's the problem, the bottle didn't say ya' or na', so i did not buy it and the guys at the counter could not tell me for sure either. Want to make sure you do not need a special cleaning fluid for the aluminum radiators. The preston anti-freeze says compatible with al rad.
get something that says for aluminum rads....its out there. you just have to look. i forget what kind i use. its some off brand but its aluminum safe
thanks 5.0. :D
