bad vibration - MustangForums.com
bad vibration
Old 09-13-2007, 01:23 PM
blk40th
Default bad vibration
ok so i just got back from getting lunch and i had the worst vibration now. its the worst when im slowing down like 40-20mph.it happens when the trans is in or out of gear, and when its out of gear the shifter handle still rattles. i just replaced the harm.balancer and all those bolts are tight and it ran great until today. since ive bought the car ive been at high speeds on the highway and i had a vibration up at like 90-110. im thinkin im going to start off with replacing the u joints.
blk40th is offline
Old 09-13-2007, 02:06 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default RE: bad vibration
ORIGINAL: blk40th
cheap and easy fix, i really suggest this. i did mine recently and the stockers were ****in TRASH. couple of the bearning were ground into dust, thats how bad they were......[:@]
now my rid is all good at all speeds. i use to have a slight vibration which is now gone.
FivePointOhh is offline
Old 09-13-2007, 02:12 PM
bamaroxz
Man could be lots of things. Simple thigs to start with are tires rotate/balance, check your brake rotors/ bearings, if they are warped or bearings badit'll do it with little pressure to the brake pedal, could be the rack n pinion, and yes u joints. Also check to see if motor mounts are tight and tranny brace is tight and bushings in good shape. Vibrations are hard to pin point, I am currently trying to find a vib in my 93 LXalso. Good luck.
bamaroxz is offline
Old 09-13-2007, 02:27 PM
blk40th
well the vibration is coming from the rear. i know its not the brakes cuz i know what warped rotors feel like. i know its gotta be the rear or the u joints. im gonna start at the u joints and go from there.
blk40th is offline
Old 09-13-2007, 02:48 PM
blk40th
i found some brute force u joints for $16 a piece im gonna pick them up and install them tonight at like 1030 after my 2nd job. this will be fun.
blk40th is offline
baddog671
07-26-2016 02:20 PM
Dathan
10-05-2015 06:52 AM
KingRando
10-02-2015 09:06 AM
ChampInSD
10-02-2015 05:55 AM
4cylinderplus2
09-30-2015 06:26 PM
Quick Reply: bad vibration
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
