The main difference between the lifters is not the diameter....it's their height. A roller ready block has higher lifter bosses. If you use the spider-dog bones kit, you will be "limited" to small base circle cams. If you use the link lifters (Comp or Crane Cams), you can install a "regular base" circle cam.
