passing emissions
Old 02-16-2005, 07:51 PM
  #21
88PatrolCar
88PatrolCar's Avatar
Default RE: passing emissions
Sounds like you have a burnt up valve, a broken valve spring or a piece of carbon is hanging up and keeping a valve from closing. Do a dry compression test and write down all of the results on a piece of paper. 125psi is about the lowest you want to go. If you find a low one then do a wet compression test on this cylinder by pouring a little oil down in the cylinder this helps seat the rings, if the pressure is still low then it is a valve, if it raises up a good amount then you have worn rings. Hope this helps!
88PatrolCar is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
TCStangerv6
10-11-2015 05:57 PM
Teddi
09-29-2015 12:24 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: passing emissions
