Help! problems with 5.0 install... - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 5.0L (1979-1995) Mustang
Reload this Page >
Old 09-18-2007, 07:48 PM
Luke805
Default Help! problems with 5.0 install...
I'm in the process of installing a 5.0 with AOD into a chopped 49 ford sedan i'm building. Here's the issues:
The motor/tranny was out of a 91 mustang. It doesn't have any of the injection/smog pump/AC etc, it now just has an edelbrock intake/carb similar to the kind you'd find on a 60's mustang. I can't use the reverse drive water pump since the rest of the items are missing to run the belt through. Can I run an older style water pump like from a 60's small block along with the matching pulleys/alternator bracket? Will I need to swap dampners or run a spacer to make the early ford accessories work on my late model motor? Any tips/info regarding what I need to do will be a huge help. Thanks so much.
Luke805 is offline
Old 09-19-2007, 01:23 AM
silver91gt
Default RE: Help! problems with 5.0 install...
yes you can run the normal rotation water pump and it should work with the right crank pulley running a v-belt system.
silver91gt is offline
Old 09-19-2007, 05:53 AM
AdderMk2
Banned
ORIGINAL: silver91gt
you have to swap the timing cover as well
AdderMk2 is offline
Granatelli Sales
03-25-2016 08:01 PM
Granatelli Sales
The New S550 2015-2019 Mustang
12-27-2015 06:28 PM
JT76
09-20-2015 11:32 AM
vintageaion
09-08-2015 10:45 AM
5.0 kevo
09-03-2015 06:24 PM
Featured Sponsors
