new bottom end how long for break in
Old 02-16-2005, 04:24 PM
westrides
westrides's Avatar
Default new bottom end how long for break in
i just put a new engine in my car out of a 89 5.0 x-cop car that i bought as a theft recovery the car was pulled out of a lake so while it was out i decided to throw new mains and rod bearings in it how long until it should be broke in or until i can drive hard again
westrides is offline
Old 02-16-2005, 05:08 PM
69mach1377
69mach1377's Avatar
Default RE: new bottom end how long for break in
Treat it like a rebuild...500 mile break in and change the oil?
Better comments to follow I'm sure.
69mach1377 is offline
Old 02-16-2005, 05:27 PM
nemethjames1
nemethjames1's Avatar
change oil after 500-1000 miles either or... and just drive it easy for atleast 500, i would say
nemethjames1 is offline
Old 02-16-2005, 11:10 PM
bobby
bobby's Avatar
change the oil after 50 miles then after 500 then after 100k then every 3k , use regular oil( castrol or havoline ) take it easy for the first thousand miles, once u hit 3k miles put synthetic in it ( AMSOIL OWNS!!! ull be fine
bobby is offline
Old 02-17-2005, 12:12 AM
mstng675l
mstng675l's Avatar
If you have molly rings and everything is put together properly there is no break in time... People will give different periods of time it is all preferance... Like i said if it has molly rings feel free to tromp on it any time you feel like...
mstng675l is offline
Old 02-17-2005, 12:13 AM
bobby
bobby's Avatar
ORIGINAL: mstng675l
ive heard that before, do 05s have moly rings? i would assume soo
bobby is offline
Old 02-17-2005, 02:53 AM
Dan89lx
Dan89lx's Avatar
my friend has had 2 motors professionally built recently, a 306 and a 351 and he ran the dog sh*t out of them as soon as the cam was broken in good. If its put together right, it should be fine.
Dan89lx is offline
Old 02-17-2005, 04:42 AM
westrides
westrides's Avatar
i think the rings are stock i never had the pistons out or heads off i just threw some new bearings in it because it was full of water and i heard they can get stained
Old 02-17-2005, 06:07 AM
bigdaddy408
bigdaddy408's Avatar
10,000 miles til it really loosens up, then you can hammer it like hell
bigdaddy408 is offline
Old 02-17-2005, 12:16 PM
C/Note
I ♥ Acer
C/Note's Avatar
my motors all have roller cams ....i just run it for say 20 mins than adjust my valves change oil ..and go ...run some 10s........most race motors you just cant put 500/1000 miles on them it would take to long.....[&:]
C/Note is offline
Quick Reply: new bottom end how long for break in
