almost figured out my h/c/i
RE: almost figured out my h/c/i
Onyx, im not saying you cant, but i am going off what the basic concept that lower the compression the more timing and boost you can run which will always equate to more power then having higher compression and less boost and is safer. I know you plan on getting a kb and you can but you would need to take out a lot of timing which would lose you hp when you could just run stock compression or even lower and crank the boost a lot higher and make more power. Thats how i did it on my car before i had my mustang and on others. I can get cheaper heads which i have and just run more boost and save money and make the same amount of power too. P zero will you give it a rest with the hi ports.
breaking
10-02-2015 01:27 PM
BeatnikFink
10-01-2015 08:00 PM
