can't get car to idle
Old 09-22-2007, 10:08 AM
jonalman
jonalman's Avatar
Default can't get car to idle
i just bought a new 347 for my 93 mustang. i installed the motor, and every since i put it in ive really been having problems with the car wanting to idle. i have tried ajusting the throttle position sensor, and there was no luck there. My timing is where it needs to be, and i really am unsure of what the problem actually is. Any Ideas?
jonalman is offline
Old 09-22-2007, 10:13 AM
jonalman
jonalman's Avatar
Default RE: can't get car to idle
i forgot to add that all of my vacuum lines are hooked up properly.
jonalman is offline
Old 09-22-2007, 10:35 AM
rocketrotary
rocketrotary's Avatar
Is it dying when it should be idling?
rocketrotary is offline
Old 09-22-2007, 11:06 AM
93lxtacy
93lxtacy's Avatar
check the fuel pressure regulator and see if it is spitting gas into its vaccuum line. i had a brand fuel pressure regulator do the same thing you are talking about.
93lxtacy is offline
Old 09-22-2007, 11:42 AM
jonalman
jonalman's Avatar
i just bought a brand new regulator
jonalman is offline
Old 09-22-2007, 11:44 AM
jonalman
jonalman's Avatar
yes, the car dies when it should be idling. it really doenst even try to idle.
jonalman is offline
Old 09-24-2007, 09:39 PM
Brian47p
Brian47p's Avatar
i have a stock 5.0 that im also havin trouble idle and everything checks out but i havnt checked this fuel regulator. it has a really rough idle and it sort of bucks when i give it some gas. any ideas? could it be from back pressure?
Brian47p is offline
Old 09-24-2007, 09:58 PM
92GreyGT
92GreyGT's Avatar
I had the same problem with mine when I put my 331 in. It needs more air to idle. You can drill a 1/4" hole on the throttle body blade or get this IAC adjuster. It helped me once I got it adjusted correctly.
http://www.latemodelrestoration.com/...1&comp=LRS
92GreyGT is offline
Old 09-25-2007, 01:18 PM
aode08
aode08's Avatar
was this a shortblock purchased? what heads are on it? pics?
aode08 is offline
msavoia23
12
07-07-2018 12:08 PM
mirandaandjimmy
11-16-2015 08:51 AM
fdnyems19
08-13-2015 09:36 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: can't get car to idle
