OMFGWTFBBQ about to start up my rebuilt engine...
ok so, everything is hooked up after a long 6 months, im about to turn the key. IS THERE ANYTHING I NEED TO KNOW BEFORE I DO THIS? its ok if i just start it and let it idle right?
thanks!!!!!!
thanks!!!!!!
RE: OMFGWTFBBQ about to start up my rebuilt engine...
ya. go to autozone and get an oil pump priming rod. fits into a cordless drill, and slides into the dizzy hole. spin it counter clockwise for a good minute. works best to have a valve cover off so you can see it reaching the top of the motor.
if its a new cam it needs to be broken in..... keep it at 2k for 20 min... dont let it idle much
my teacher builds motors often, and has been for a while, i have him for engine repair... and that is one thing he has drilled into our heads... its crutial to let the cam break in properly
ORIGINAL: dimebag
Maybe flat tappets or mechanical cams, nothing of that sort for hydraulic stuff.
If you don't want to buy a priming rod, you can use a 1/4" socket and some extensions. If you do this though, you need to be VERY CAREFUL that they don't come apart. I duct taped mine together very securely, and had no problems. Remember, counter-clockwise.
ORIGINAL: jagman454
thanks!!!!!!
thanks!!!!!!
