Whole lotta shakin goin on...
RE: Whole lotta shakin goin on...
ORIGINAL: bbbngowc
The what? [&:]
ORIGINAL: 93 LX FiveO
look at the harmonic balancer
yes its quite common for the harmonic balancer to go bad, when it is idling take a look and see if its wobbling or if the rubber has come out etc, let us know im glad you figured the idle problem out
ORIGINAL: 94 G STANG
It hasn't been confirmed that it is the Harmonic Balancer. That's just an idea that I will look into. My dad said he thinks it's the fan, because when he looked at it, it looked warped and really used. Could a warped / wobbly fan cause the shaking as well?
ORIGINAL: bbbngowc
ORIGINAL: HaV
A warped and wabbly fan would shake, but you would really be able to see it with the hood up, and it would not be shaking the whole front end of the car.. would just be shaking in its own enclosure.. not enough mass or force to really notice.. would be a lot more likely to hear it than feel it.
Good point.
Replacing the harmonic balancer doesn't look like a simple job. I just took the car for a drive and man, that shaking is more than I remembered from the last time! This only started happening after I took the car to the body shop for repairs (hood flew up). Before that I didn't have any problems. Do you think they didn't put something on properly and that's why it's shaking? Perhaps they let out a screw or something?
ORIGINAL: HaV
The harmonic balancer is a dampener to reduce the vibration on the crank.. it will look somewhat like a pulley with no belt going to it on the end of your crank shaft... your probably getting vibrations all through the rpm range, just not enough to feel. I would double check and make sure your not getting a misfire but really does sound more like hte dampener..
ORIGINAL: bbbngowc
The what? [&:]
I checked for the harmonic balancer and I don't see it. All the pulleys in the front is in contact with the belt in some way. Perhaps my belt is on wrong?
ORIGINAL: bbbngowc
ORIGINAL: HaV
ORIGINAL: bbbngowc
The what? [&:]
What if the firing order of the spark plug got messed up? Like the wires are set properly. Would that cause the shaking? I took it for a test drive yesterday and the car is shaking (violently) clear through 3000RPM then it smooths out.
KEM Motorworks
08-14-2015 10:13 PM
