Taurus Fan Install Help...
RE: Taurus Fan Install Help...
Yea I have a CSR thats "universal" and the Canton is 87-93 specific. I guess I will just wait until I get the Canton and see which one works best, where at, etc.
If anyone is already using one LMK where you have it at.
It would be able to but it has a bracket that you mount and than mount the can inside the bracket. The problem is, the bracket screws in from behind so it wouldnt be able to go through the radiator... the fan shroud possibly but thats it. The universal can is like 3 1/2 wide and 9" long. The 87-93 specific is like 2 1/2 and 13" long. They bolt hold 2qt's though.
I fabbed up the two brackets for the fan to radiator shroud using eigth inch by one inch steel, I did the same with the factoryover flow tankas well. I can take some pics for you if you want me to.
