cast iron trick flow high ports with solid roller
Old 09-26-2007, 11:36 PM
FunctionB4form
FunctionB4form's Avatar
Default cast iron trick flow high ports with solid roller
this cam has about 600/600 258 duration.
the valves are stock in the cast iron trick flow high ports
how bad will the valves hit the head?
FunctionB4form is offline
Old 09-26-2007, 11:58 PM
FunctionB4form
Default RE: cast iron trick flow high ports with solid roller
i forgot to clay it before i put th heads on and im scared they are going to hit now
Old 09-27-2007, 07:00 AM
86HOGT
86HOGT's Avatar
Better pony up the money for another set of head gaskets...better to be safe than sorry, bro.
86HOGT is offline
Old 09-27-2007, 08:03 AM
aode08
aode08's Avatar
yeah they will hit the pistons without the pistons being notched
aode08 is offline
Old 09-27-2007, 08:49 AM
FunctionB4form
yep..thought so!
i hate getting the expensive gaskets too
GimpyHSHS
19
12-19-2023 01:12 PM
Dokilar
15
10-16-2015 08:13 PM
Urambo Tauro
10-05-2015 09:37 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: cast iron trick flow high ports with solid roller
