fpr
fpr
my friend has a bbk fuel pressure reg for 60$ should i get that or just buy a kirban or w/e the name is. also how would i go about installing it. do you remove the factory one or is that part of the fuel rail? or should i just go right on the schrader valve?
RE: fpr
The factory one disconnects from the fuel rail via 3 allen bolts. They're all very fun to get to. Easiest way to remove it is to unbolt the throttle cable/kickdown cable bracket and move that out of the way, a lot more room there. Once you find out what size it is (can't remember exactly) you'll need 2-3 of those allen wrenches, and have to cut the short side down to various sizes to gain enough room to access the bolts.
Once you've had practice with them, you can actually get it done fairly quickly.
As far as which new one to buy, somebody else would be more qualified to tell you about that.
bearster18
03-29-2006 06:23 PM
