Cold Air Intake Question
Old 09-27-2007, 06:13 PM
SayWhen5.0
SayWhen5.0's Avatar
Default Cold Air Intake Question
lookin to buy a BBK cold air fenderwell intake.........................good/bad?? any input appreciated
also
whats all this talk about a "Speed Density Fuel Injection" does that have anything to do w/ Mass Airflow or something??? i have an 87 5.0 GT.........if anyone can explain the Speed Density thing id greatly appreciate it
SayWhen5.0 is offline
Old 09-27-2007, 07:10 PM
golden_eye
golden_eye's Avatar
Default RE: Cold Air Intake Question
Speed density was what the Mustangs used to read airflow and meter fuel before Mass airflow was introduced. Speed Density has a MAP (Manifold Absolute Pressure) sensor that has a vacuum line hooked to it from the manifold. Mass Airflow has a sensor right after the intake filter to measure the airflow. I believe that Mustangs switched from SD to MAF in '89. I'm not too sure on the advantages of one over the other, but you will have differentpeople tell you that each one is the best.
golden_eye is offline
Old 09-27-2007, 07:51 PM
shawnk007
shawnk007's Avatar
just get a cold air intake off ebay......its the same thing........
shawnk007 is offline
Old 09-27-2007, 07:57 PM
94StinkinLincoln
94StinkinLincoln's Avatar
use the stock air filter system. you wont gain hp with a bbk, i have one, it gets VERY hot under the hood and you can loose hp that way. also the air filter can let more dirt in, sure you can spray it w/ oil, but the oil can get on the MAF and then u got idle and power issues. the stock air filter is easy to get ahold of, any parts store, the bbk, not so much.
94StinkinLincoln is offline
Old 09-27-2007, 08:14 PM
jthorn9
The Godfather
jthorn9's Avatar
ORIGINAL: 94StinkinLincoln
I have a BBK with absolutly no problems. Granted, while it gets hot under the hood, the air does not sit in the air intake long enough to heat up, and the intake itself does not get very hot, I find the upper intake to be hotter than the cai and my upper intake isn't chrome. The CAI gets warmish, but not hot by any means. I also don't have dirt problems. I cleaned all my intake sensors after I bought the car, and no dirt has really collected on any of them, and I do regularly check just to make sure. I've had my BBK for about a year and a couple of months, still looks brand new.
Also, ebay cai = [:'(]had one on my old sixer and other than the K&N filter the cai quality was plain crap.
jthorn9 is offline
Old 09-27-2007, 09:15 PM
88BlueGT
88BlueGT's Avatar
ORIGINAL: shawnk007
Not always.......
88BlueGT is offline
Old 09-27-2007, 10:16 PM
OnyxCobra
OnyxCobra's Avatar
I agree with getting one off eBay, mine's identical to a Mac intake and was like 1/3 the price. Works mint.
OnyxCobra is offline
Old 09-27-2007, 10:27 PM
Scout2232
Scout2232's Avatar
I havea modifiedBBK fenderwell kit on mine. I really like it, it makes things look clean and you dont have anugly looking(opinion)air filter to look atwhen youopenthe hood.
You need to know whether you have speed density vs mass air ona CAI setup because the mass air meter takes up about 5 inches in the intake plumbing. So if you bought a mass air CAI for a speed density car you would have to make up the 5 inches of distance you are missing since you don't have a meter there. Likewise if you bought a speed density CAI kit for a mass air'd car you would need to hack about 5 inches out of the intake plumbing because it would be too long to fit the meter in.
If you have 89+ you have a mass air'd car (also '88 California Mustangs had mass air as well) otherwise its speed density.
This is what it will look like if you have a mass air'd car.
Scout2232 is offline
spectreman
03-31-2016 09:26 PM
JonnyBlazeGT
11-03-2015 01:10 AM
09-01-2015 08:16 PM
Calizic
08-28-2015 01:46 PM
12bigredstang
08-25-2015 04:58 PM
Quick Reply: Cold Air Intake Question
