Drag Springs
Drag Springs
I currently have Ford Racing "B" Springs and I enjoy the lowered ride height but the ride is extremely harsh because of the springs being so stiff.
Anyway I race the car at the track a lot (when it's not raining...) and want to put a set of drag springs in that will lower the front of my car covering the top of the front tire about an inch and the rear up a few inches to clear my 275/50s so they don't scrape the fender.
To the point here, if anybody has a suggestion on a soft spring that will make daily driving a little more smooth that would be great.
-Jeff
Edit: don't want to look stupid here,I diduse search but wanta drag spring that will sitcovering the front tire an inch or two.
-Jeff
RE: Drag Springs
You can get 4 cyl front springs or cut any front drag spring. I ran moroso's when I had an 86 and the 2 different spring rates on the back made turning a little uneven especially with no sway bars.
RE: Drag Springs
i think if u wanna go as low as your saying, and still be "drag racing springs" u should look into coilovers... they have a few sets of springs out there that are softer for drag racing, not handling like most coilovers
and the thing about cutting drag springs, is it kind of defeats the purpose of them...
RE: Drag Springs
If you want to raise up the rear to clear slicks, buy some weight jacker control arms, especially if you dont have rear control arms anyways. I have a pair, I like em alot, but you gotta be super man tojack those things with a breaker bar while its sitting on the ground...
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
