Gear Install
Gear Install
I just ordered 3:73 gears and all the install parts needed. What is the best type of rear axle fluid to use? is there a certain brand or type to use thats better than others? How much should i expect to pay to have the gears installed?
RE: Gear Install
There is no real special oil to use unless you are going to go synthetic.. I believe Royal Purple makes synthetic oil for rear ends.... You will also need the limited slip additive which ford makes.... You can find this at a local ford dealer or speed shop... Most of the time the shop installing the gears will already have these things...
RE: Gear Install
yeah, make sure to get aditive... but essentialy oil is oil.... i got burned the first time i paid a shop.. i supplied fms gears, and there labor was 450+.. i was stolen, now there out of buisness.... LOL
RE: Gear Install
for those prices, dont rule out doing it yourself. i did mine, but the book can probably explain better than i can. As far as oil goes, synthetic is better than non, but i dont think brand matters too much as long as you have friction modifier.
[IMG]local://upfiles/12913/C51407C1F7354EDD95F272C325A49CBC.jpg[/IMG]
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
