FRONT lowering springs
I was wondering if any company offers just the front lowering springs without the rear lowering springs...... i am happy with my rear height and i wanna put bigger tires in the rear, but in the front, it looks rediculous. Thanx
RE: FRONT lowering springs
you could use drop spindles from racecraft http://www.racecraft.com/proddetail.php?prod=300101 if you only want to lower the front but it contradicts your not wanting to spend much money because they are like $500
Normally drop springs will be stiffer, so your car will ride funny. Most spring kits only drop the rear a fraction of wut it drops the front, just because the front usually sits higher. A FRPP kit is like, $140, you might as well spend that much on something as important as springs, or you could always only use the front springs, or cut the front, but the car will lean more.
09-16-2015 07:53 PM
