i have this hiccup while driving its seems like one of my cylinders isnt getting spark so im replaceig some wire and plugs and cap rotor and coil , cuz its all corroded
clean that off and see if your problem gets better. baking soda and water(half and half). pour it on the corrosion let it sizzle away wash with clean water then wipe off with dry towel. most like the corrosion is your problem. is the corrotion on the cap or the coil? or inside the plugs? start with cap plug and rotor since those are cheap and then thecoil if you have to.
i replace my cap and rotor , my wires are really worn out so i just orderd some frp 9mm and my coil is eaten to ****, there is no lip on it and it wiggles, that might be my problem, i mean the problem didnt start to happent until i started to mess with my coil cap rotor, wire and plugs etc , so its like find waldo =/
