Warm Pinging
Warm Pinging
Hey gang,
I bumped my timing the other day. It started out at about 8 and I was able to get it up to 11 without pinging on the test drive. It has been fine since with heavy acceleration, until this weekend when I used it to go on a 2.5 hour drive to my grandparents. Toward the end of the trip (while the engine was good and warm), it would occasionally ping when accelerating heavily, but not always. I run the highest octaine fuel when I stop to get gas, so it's always between 91 and 93 octane. I was just curious if anyone else has experienced this, if it is comon,and if it is a huge deal. If need be, I can always put it back to 8, but like most people I enjoy the added throttle response it gives.
Thanks for any input.
RE: Warm Pinging
Try running some seafoam. If you have a lot of carbon buildup, then it can increase pressure and cause some detonation. It's fairly cheap and may help you out. Either that or take a degre of timing out. But it shouldn't be pinging at such low levels.
I'm assuming your N/A?
RE: Warm Pinging
ORIGINAL: samseed101
I'll run the Sea Foam, since I haven't done it to this vehicle yet. Couldn't hurt. Otherwise I realize mybest option is to just take it back a degree. I just wanted to see if anyone has experienced this before.
Thanks for the input.
bryan616fl
01-25-2019 09:07 PM
