Eaton True Trac
Eaton True Trac
Alright heres the deal i was ordering all of my rear end parts off of moser engineering and i saw that they have diffs. They have diffs called Detroit True trac they are made by eaton so they must be good but i was wondering if anyone had any feed back on them. good? bad? thank you
RE: Eaton True Trac
I have one and love it. It's perfect for the daily driver since you won't have the clunking and such with a locker when going around turns. I've had it for going on 3 years now I think still burns 2 and I've had no problems. I would definitely reccomend it over the factory trak-loc, as those are pure garbage in my opinion... If you have any specific questions or whatever fire away.
RE: Eaton True Trac
Awesome thanks your car is gorgeous by the way dam lol yeah i ordered a whole rear setup off moserenginnering and i saw that they had those diffs so i just got one i was originally going to get a eaton but eaton makes true trac anyway i deff was not going to get a spool or anything they are just not ment for the street. I was just a little worried about the true trac because it seems to me that it is ment for more 4 wheel drive use and i know it can handle alot of torque but i was questioning the power and et it can handle i make around 4 or so run like 11.4 for now with tthe blower i have. I got the 31 spline true trac diff 31 spline axles c clip elimanators and rear main girdle and a set of 4 10s . So i just wanted to make sure i bought a good posi.
RE: Eaton True Trac
you should have done some kind of search on diffs. on this forum because i have said this MANY times, I LOVE THE TRUE TRACK. it makes 2 DARK black lines going strieght but you can feel it working when your tires slip around corners. then you put the gas on more and it locks. its a great piece of metal!!
treesloth
09-28-2015 07:03 AM
09-16-2015 07:53 PM
