a 408 will only require a 351 efi intake, oil pan and pick up, and crank pulley spacer part# m-8510-b351 from ford racing. and of course the oil pump is differant also and so is the pump drive.
you are gone to need headers also a distributor to fit a 351. the front mount bracket for the power steering and alt.you will also need a new fly wheel or flex plate if you run a auto and a new damper if the motor dont come with one cuz. the balance for a 351 is 28oz and the 5.0 HO is 50oz.
yes ..the 351 is a small block..and it will fit the aod as the bell housing is for a small block..but in my oppinion ..the 347 is a better swap...easyer to do with out having to dig up all the other parts to kae it fit..the 347 will drop right in...not parts finding..
