running rich help
running rich help
pulled codes and says high voltage running rich for both sensors they are both brand new, the car also rescently is starting to buck like a horse and is having a hard time going from a stop to a roll, could this be my tps, its set at .98 but the ground wires are showing and exposed. it feels like its misfiring
RE: running rich help
ya i can smell gas in my regulator vacuum line i kinda fixed it the hose was clamped, and i replaced my tps with a bbk one and cleaned my act thanks bro for the awesome help, it kinda will buck every once in a while so i might just go buy a new act and i have some frp plug wires comming so it shouldnt lose spark
the hose was clamped[&:]??? I think what he means is if you smelled gas in the vaccum line to the regulator he was hinting at the diaphram may be ruptured allowing the vaccum line to draw gas into the intake when it should not be doing that...the regulator is controlled by vaccum so when you romp on it the vaccum signal is lost and up goes the fuel pressure to supply the necessary amount for WOT.
