how do i know if a cam lob is wiped out??
RE: how do i know if a cam lob is wiped out??
well i dont think i have that prob but i was told to watch out for that because i dont think my roller rockers a adjusted correctly and i dont know how to do that i have ford racing roller rockers they are pedistal mont bolt down style is it with shims??
You'll need to take the valvetrain measurements (lift and duration)in order tocompare them with the cam's manufacturer specs.
IF the lifters were bad, rocker arms out of adjustment, the oil not changed regularly, and/or the motor consistantly over-revved, the cam could be worn also. As for a noise? It may be valvetrain noises (tapping) coming from the top of the engine.
You didn't give any details. Why do you think your cam is wiped out???
OR
Or just take the cam over to a good machine shop and have them compare it to the original specs. This assumes you know 100% what cam you have.OR
Sometimes youcan tell if the cam is worn by visually looking at it,(when it's out of the engine of course). Just look at the lobes and see if they're scored or burned on the sides of the lobes and shiny in the center.IF the lifters were bad, rocker arms out of adjustment, the oil not changed regularly, and/or the motor consistantly over-revved, the cam could be worn also. As for a noise? It may be valvetrain noises (tapping) coming from the top of the engine.
i dont think my cam is bad but
the cam thats in it looks like that i thought it looked odd but i was told by a couple of shops that it SHOULD be fine you think thats my prob?? i have an E-303 to replace it (stock cam is in right now) but if i put the E-303 in there im worried bout clearence issues my motor was 0 decked and the heads were shaved 0.020" would i have clearence probs?? what springs should i use??
ORIGINAL: n2jmk
[align=center]OR[/align]
Or just take the cam over to a good machine shop and have them compare it to the original specs. This assumes you know 100% what cam you have.[align=center]OR[/align][align=center][/align]Sometimes youcan tell if the cam is worn by visually looking at it,(when it's out of the engine of course). Just look at the lobes and see if they're scored or burned on the sides of the lobes and shiny in the center.
[align=left][/align]
Stock 87 - 93 5.0L engine with stock heads?
The "E" cam only has a 0.498" lift; you will be fine. Once cam lifts go above 0.512", you have to check valve-to-piston clearance and consider flycut pistons. You'll be fine with the "E" cam.
ORIGINAL: AdderMk2
as long as you are not running 1.7 roller rockers, the E cam will fit fine
ORIGINAL: BlackLX_92
how do i know if i have 1.7 roller rockers cuz i do have aftermarket roller rockers but i dont know which ones they are they were on it when i got it
ORIGINAL: AdderMk2
