help installing msd 6al on a 93 5.0
RE: help installing msd 6al on a 93 5.0
the tt's have already been installed, but the pos turbos Ihad have to rebuilt. I don't need to race i just traded it to get it fixed so I can make a lil money. My bad on the MSD I just figured all the wires had to be hooked up my bad guess I'll not ask anymore ignorant questions, but thanks for all the help
Like i said it took 3 mintues with the harness, it plugs into the coil and the other end plugs into the connector. the 4 wires coming out splice into the 4 msd wires of the same color. Almost as easy as installing SLP exhaust
just put a new 6al on mine and yes the white wire if grounded an used with a toggle can be a security switch, you have two red wires, one needs to be hot all the time an one with ignition, you have a green and purple that goes to the distributor, an orange and black that goes to the coil and then a ground wire. nothing to it. make sure the connection near the box on the purple and green wiresare snug. a few weeks ago the prong came out of the clip on mine an it slid back into the jacket where i couldnt see, took forever to find the problem
BUY THE HARNESS!!!!
Its so much easier, plus if you ever have any problems with it (mine went bad a few months ago) you can just unplug it and run off of the stock ignition
