leaking around tail shaft what is it?
RE: leaking around tail shaft what is it?
everything is tight...very littles play...think that old c6 yoke could be my problem? it wasn't in the greatest shape either.
ORIGINAL: mustang8719
Also to be safe before you remove the drive shaft see if it flops up and down at all.There is a brass sleeve inside the tailshaft that helps support the yolk.Sometimes that wears out and the driveshaft wobbles a little in the trans causing it to start leaking.
I inserted a pic the part im talking about is #7
[IMG]local://upfiles/7528/4BAD78148EC4452484E8C952E90FBC26.jpg[/IMG]
That could be possible.Try to measure it and see if you can get spec's of a new one.I knwo my old yolk had a pretty good groove cut in it.I also put another yolk in at the time.
bradleyb
11-27-2015 07:50 PM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
