right cam for the job
I am building a new engine from the ground up for the first time.
Here is where im at now.
306 w/ speed pro forged fly cut
windsor sr heads ported and polished. rebuilt valve train binding at about .650 flows 280/180 at .600 lift.
port matched victor jr
min carb is 650cfm..do have on yet.
built AOD with 2800-3200 stall hasnt been on the road so i dont know exactly.
4:10's
this is the cam im looking at.
CamStyle:
Hydraulic flat tappet
BasicOperatingRPMRange:
2,800-7,000 RPM
IntakeDurationat050inchLift:
250
ExhaustDurationat050inchLift:
256
250 int./256 exh.
AdvertisedIntakeDuration:
294
AdvertisedExhaustDuration:
306
AdvertisedDuration:
294 int./306 exh.
IntakeValveLiftwithFactoryRockerArmRatio:
0.554
ExhaustValveLiftwithFactoryRockerArmRatio:
0.558
0.554 int./0.558 exh. lift
LobeSeparation(degrees):
110
IntakeValveLash(in):
0.000
ExhaustValveLash(in):
0.000
GrindNumber:
FS XE294H-10
what do you guys think. let me know what you have had luck with.
occasional DD mostly just streetfun and bracket stuff.
4:10's
CamStyle:
2,800-7,000 RPM
250
256
250 int./256 exh.
294
306
AdvertisedDuration:
294 int./306 exh.
0.554
0.558
110
0.000
0.000
GrindNumber:
FS XE294H-10
RE: right cam for the job
Your stall might be kinda small. I have a cam pretty close to yours with the AOD. When I throw it into gear it boggs down. I have a 3000 non-lock up by hughes performance. I wish I went with there 3500 or 4000.
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
