car wont stay running? help
RE: module going bad? need help
know how , just dont have the proper tools at home. Any ways its not the pick up. any other ideas? Just for the sake of argument I put another module on just to be sure. same problem.
any idea's tps was measureing .8 volts yesterday, tonight it was measuring 1 volt. I took it off to enlarge the holes to adjust it and now 0 volts to .2volts. I have re installed it 3 times and the sdame problem. I think I may have found my problem.
RE: car wont stay running? help
This morning I tried to start mine and I had to hold the key in "start" and it just kept turning over but only hitting on one or two cylinders. When it finally did start I held it up at around 3K RPM and it would just cut off dead. I got it running at one point and it ran for a few minutes and then it would start running really rough, like cylinders were missing, for about 20 seconds then cut off. I haven't tried messing with the key while it's doing it. I can try that tonight or tomorrow.
It doesn't seem to be an issue with the ignition key. I started the car and moved the key around as much as possible and it didn't seem to have any issues.
The problem seems to be getting worse. I haven't driven the car in weeks because I used to be able to drive it back and forth to work and it would only cut off 2-3 times each way. Now I can't even get it out of the driveway.
This morning when it finally started and held it at 3K RPM and it ran for 20-30 seconds and stumbled twice (drop to 2500 and back up to 3K) and then cut off. Whenever it cuts off I can hear the fuel pump run for a few seconds. Everytime I try to start the car it's very slow to start and usually only runs a few seconds before cutting off again.
Someone...Anyone...help please! This is very frustrating!!!
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
