valves
valves
i was researching some heads rhs 180cc heads for my 302, and one of the tests they did said that it would give better flow if equipped with larger valves. they said they were using 2.02/1.60 valves. so my question is would i be able to fit larger size valves and have enough clearance in on my stock block using regular 302 pistons without any issues?
RE: valves
ORIGINAL: FLcracker9
No. From what I understand, you can't even use the 2.02 valves with your stock heads. Do a search on 2.02 valves, or search "heads", and you will find plenty of posts regarding this subject.
TfcCDR
09-14-2015 12:08 PM
