Heat ?
Heat ?
I have an 86 GTwith 45,000 original miles
When I turn the heat on, place theswitch on vent I have way more air comming out of the driverside dash vents then the passengerside vents.IfI move the switch to defrost and feel the defrost vents the the same applies. The air is constant and there are no noise. WHY ?
RE: Heat ?
you've got a blockage or restriction somewhere in the vent......on the 85/86's you can cheat the blower motor assembly down and remove it after removing the glove box and then you can look up under the dasd and access some of the necessary vents.......I removed my heater core in less then 45 min from my 85 this way as the heater boxes in the 85/86 are a different set up then the 87-93 dashes...trust me I know..just last week I did the heater core in my 92 ..I wish it had of been my 85 that went bad cause I know how easy that one is.........
RE: Heat ?
ORIGINAL: ponyboy88
looking at doing my heater core, (and damn its getting cold quick) i got an 89, is it really a 9 hour job?
RE: Heat ?
I drove the car the other day and when I turned the heat off I heard a kind of puring type noise like the air is rattling through you know one of the doors in the heater vent inside the dash. I think maybe that ther is a door that id not open all the way. Can I stick a coat hanger or something in there to try to push open what ever is in there?
I'm pretty sure no mouse this car is kept mint. I love the thing I can't tell you the last time I saw a gt this nice.
RE: Heat ?
ORIGINAL: ponyboy88
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
