Vibration--HELP!!!!
RE: Vibration--HELP!!!!
ORIGINAL: bbbngowc
ORIGINAL: bbbngowc
It's vibrating only at moderately high speeds? Harmonic Dampner perhaps? My car vibrates really badly at low rpms and the shifter as well. When I go to 50+ it smoothes out. Someone told me, if my vibrations happens at high RPM then it would be my Harmonic Dampner/Balancer. Since mine has the shakes at low rpms it's probably my fan and clutch causing it. I'm replacing those next week.
Its vibrating at 80mph. No matter what gear or RPM. Could it be due to the rear control arm bushings being wore out, not gone, just wore out? Harmonics???? Also found last night that the harmonic balancer is going apart also. Have swapped tire/wheels and still same vibration. Again, thanks alot guys for the ideas.
