What to do if engine is ticking
Old 10-15-2007, 02:46 PM
dimebag
dimebag's Avatar
Default RE: What to do if engine is ticking
... is it low on oil...[&:]
dimebag is offline
Old 10-15-2007, 03:41 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: 93 LX FiveO
i thought glowing headers indicated a lean issue
In issues of timing where a header is glowing red this is why such occurs.....because the timing is retarded the cumbustion process starts late and finishes late and when the exhaust valve opens the cumbustion process is still taking place therefore the flame is blown out into the exhaust and heats it up to extreme temps and causes the header to glow red!!! run to long this way will burn an exhaust valve!!!! danger danger.......to correct this problem you advance the ignition timing and therefore start the combustion process so it is finished before the exhaust valve opens otherwise damage will occur...hence if ignition is incorrect and does not occur when it's suppose to where it's suppose to it'll cause such problems.......excessive lean fuel mixture can cause the same but I doubt that is occurring in your fuel injected car unless maf is bad and or injectors are plugged and if it wasn't that way before the h/c/i swap you can rule that out anyway I hope I was simple enough in my explanation of ignition timing as to not get anyone technically confused by using big words
mjr46 is offline
Old 10-15-2007, 04:04 PM
PJB
PJB's Avatar
I used to have a header leak from loose header bolts that caused a ticking and I just had to tighten the bolts and it went away.
Now Ive got a tick coming from a few of the lifters when the motor is warmed up.
PJB is offline
Old 10-15-2007, 04:55 PM
5.0stanger
5.0stanger's Avatar
ORIGINAL: 94RedDevil
dudes, all i need to do is get the car to where i can drive it for like 100 miles to break in this clutch and i have an appointment to take it to get dyno tuned on thursday and then i can leave it to their expertice. any advice is appreciated
Time the damn thing right, then give us additude.......
5.0stanger is offline
Nick Oliver
10-17-2018 04:22 AM
SteelerNation82
09-16-2015 07:11 AM
rksnow1
09-14-2015 08:46 PM
Pyrate Dave
09-10-2015 07:30 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: What to do if engine is ticking
