how do remove the motor mount on the driver side?
i got the top 2 small nuts off. now there's 2 big bolts on the bottom.. one is blocked by a fluid line and it looks like its hard to take off.
RE: how do remove the motor mount on the driver side?
there are only three bolts that hold it on ....two in the block and one big one that that goes to the k- member the others you remove..at least I do when it's out.....they just hold the mounting bracket to the mount.........you'll have to place a block of wood under the oil pan and jack the motor out to get sufficient clearence to remove the mount
yeah i noticed theres only 1 bolt on the bottom..
i'm trying to figure out how to get to it..theres a pipe line in the way of it.
its too hard to get a wrench on it.
I use a 1/2 drive socket on a universal and an extension that's about 10 inches long and an impact...if you don't have an impact use a breaker bar on the end of the extension instead
