5.0 non HO VS. 5.0 HO
RE: 5.0 non HO VS. 5.0 HO
ORIGINAL: Cobra77
Cam, heads, throttle body/egr spacer, firing order (which I believe includes the computer since it has a roll with the injectors). I'm sure somebody else will chime in with others.
Correct.
The typical 5.0 Crown Vic engine should not be tossed aside and can be used as a suitable core. You are going to dump the stock heads and cam and stuff anyway if you rebuild for performance.
if your thinking you can just swap in a FInon H.o into theFI H.O , you are wrong . DO NOT EVEN TRY, me and my dad just went through all that this summer. unless you are going to carb it, ittll be a pain in the ***. the guy we bought our motor off of said it was a roller HO. nope, didnt even bother taken the valve covers off till it ran like ****..... so just in case your thinking of trying it, i would highly advise not..
ic. toying with the idea of building an engine for my stang. the engine ihave in now will stay bone stock for now.how would i be able to tell the difference between a roller vs a non-roller block? im sure the grooving for the valve train is different, but my knowlege with the valve train is limited at best.
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
