vacuum line? (pic inside please help)
see the taped up line that goes into the back of the upper intake? i just bought this car (not the pic above) and it looks like someone somehow crammed a paper ball into the cut off hose, and now i just got my car back from my mechanic and the ball is gone, just the hose, and it makes a farting noise and sucks in air. what should i do? the egr spacer is also capped off if that helps
RE: vacuum line? (pic inside please help)
looks like the air injection tube that goes to the back of the heads is covered with tin foil and the accompanying vaccum connector you are holding is unplugged
that is not my pic, but yeah im talking about the one covered in tin foil, should i plug it or get some kind of filter for it?
ORIGINAL: mjr46
ORIGINAL: sprayed306
your going to want to plug it
you unbolt it from the back of the motor and thread in two 5/8x11 bolts.. no longer than 3/4"
ORIGINAL: AdderMk2
PLUG IT???? are you ****ing mental?!?!?!
jwog666
12-27-2021 08:09 PM
TfcCDR
09-14-2015 12:08 PM
