Cali Smog Sucks!
#41
RE: Cali Smog Sucks!
ORIGINAL: PX429
as far as other mods, I'm going to put the stock cat's back on, I heard BBK's suck for smog.
#42
ORIGINAL: cleanfitty
Yes, you'll need all 4 cats on there or you won't pass the visual undercar mirror inspection.
#46
Hi, this post is very informative; however I would like some specific information. If someone can help me then please send me a private message. Best Regards, Property Directory | Wholesale Billiards Wholesale Batteries Something Directory
#47
This is what i did after i failed 2 times.....did complet tune up cap, rotor, wires, plugs, oil change, fuel filter and heres the fun part i ajusted the tps to lean it out just alittle then i disconnected the plug from the dizzy to bring it to base timming and brought the idle up to about 800-850 range.....also i used 93 octaine and drove it around for about an hr then the last 15mins i drove her hard and let the car run wile i was waiting to get it done and she passed with flying colors i mean as good as a new car......ohh and i used garunteed to pass crap the second time it work alittle bit..........this is my resualts back in july, HC ppm 40km/h Limit 66, Reading 48, CO% Limit .37 Reading .10, NO ppm Limit 757 Reading 364, Curb Idle HC ppm Limit 200, Reading 85 and CO% Limit 1, Reading 0.01
well i hope that help you, good luck
#48
ORIGINAL: PX429
[sm=icon_rofl.gif]
Seriously though 87 or 91?
ORIGINAL: djcondo
could shell gas make a diff. they brag about how great it is and how clean it keeps things
I had the same problems last month dude. Listen to me cause I had to do this. Run Shell 91octane, take the timing back like they said, and make sure the car is as warm as possible. Is you seafoamed you car like I did, get new plugs. Smog sucks. Im paying someone off next time
#49
ORIGINAL: 94 G STANG
You can pass visual with a carb? if the tech is your pal he could have easily disconnected your spout connector and bam another guarantee pass scenario.
bradleyb
11-27-2015 07:50 PM
