PRO M 75mm Bullet - somebody help me
Every since I put on my proM 75mm bullet the car has lost bottom end power, it is a 75mm unit with a sensor that looks exactly like a stock one- Why did I loose power? I was just looking on Corral and seen that others have the same problem. I have a K+N cone filter on- should I replace it with a stock box? I am frustrated, it would be so much easier just carburate that bit*h
RE: PRO M 75mm Bullet - somebody help me
Nevermind...just read your sig...all I can think of right now is that when you build a motor to go fast in upper RPM ranges, you're going to lose some low end power.
true, but that MAF really hurt it on bottom end, it was good before. I liked the way it ran better with the stock MAF, i did notice that it runs a lot meaner before the motor gets hot as hell, I think that cone filter is screwing me up too sucking all that hot engine air
Get a fenderwell mount, and go with a 65-70MM TB unless you have some kind of power adder... That will take care of your bottom end and get cooler air into the engine...Good luck..
Did you have the MAF cal. for a fender mount or a cone filter? I'm running a 75mm Pro-M with a 65mm TBw/EGR spacer , fender mount CAI and have no problem. My motor is completly stock.
everything is matched for #24, i got it used and the boy had 24's, i dont know if its calibrated to be used with a CAI or a stock box, I think there is a diffrence, right? It looks like a stock sensor on the MAF itself, i also have a thing called "the air adjuster", its just a little meter with a display telling how much air is being pulled through the maf, it was on there when i got the car. When i bought the car it had #24 injectors and a stock maf and that adjuster thing. Maybe i should take the sensor off of the maf that was on the car when i bought it and put it on the proM, something is fishy here because I know a pro m meter has a pro m sensor, doesnt it? I am confused.
