electric fan
RE: electric fan
ORIGINAL: 86 5.0L
I use the high speed [8D][8D][8D]
ORIGINAL: HACKGT350
3.8 touras fan its a 2 speed only use the low speed. it was worth the 25 bucks from the junk yard
and yes i have some pictures i just need to dig them up
RE: electric fan
For the love of god do not get a flex fan!!! If you rev yer motor to high they have a tendency to fling apart. but if you must get a flex fan as an alternative to the electric fan be sure to mount it backwards. reverse rotation water pump. believe me i had one
RE: electric fan
I just recentaly put on a flexalite black magic extreme #185 off ebay for $270 this fan kit is made just for the 5.0 and is pretty simple to install, fits/seals well and comes with good wire and a nice thermostatic controler with A/C and manual inputs to turn the fan on. Its an awsome fan i think and bolts on easy(dont have to worry how to mount and wirelike the tauras fan) and has brackets for you to remount the overflow tank(i had to coustomize the filler lid/low coolant sensor so the connector would reach, but that was simple) only recomendation is do the alternator upgrade because running lights heater fan and this fan will kill factory alts.
Jegs link for the fan : http://www.jegs.com/webapp/wcs/store...0002_331086_-1
Seanam
10-04-2015 10:15 AM
mrappe
09-26-2015 10:16 AM
09-25-2015 09:06 AM
