adjusting pedistal rockers
Old 10-19-2007, 09:06 PM
andywear87
andywear87's Avatar
Default adjusting pedistal rockers
i was wondering how to properly set pedistal rockers my rockers are a little noisy right now and i didnt know how to set them correctly. thanks for any help
andywear87 is offline
Old 10-19-2007, 09:10 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: adjusting pedistal rockers
you bring each cylinder up to tdc...I follow the firing order this way I can adjust both intake and exhaust rocker all at once on that cylinderand then tighten the 5/16 bolt while spinning the push rod and when a slight drag is felt then from there in less then 1/2 to 1 full turn the torque on the 5/16 allen bolt should reach 22-25 flt lbs if not then you need to use a shim under the pedastal to reach proper lash adjustment
mjr46 is offline
Old 10-19-2007, 09:15 PM
andywear87
andywear87's Avatar
thanks for the help so it is approx 1/2 turn after i start to feel drag? can i just torque them to 22-25 ftlbs the are afr heads if it matters
Old 10-19-2007, 09:24 PM
mjr46
mjr46's Avatar
no, you need to reach the torque by the time you reach the specified turning range cause to much if you don't pay attention could compress the lifter lash adjuster into the bore to far resulting in a possible lifter that'll bottom out in the bore and bend a push rod and or cause drivability issues if the valves are to tight...I adjusted mine to tight infact way to tight many years ago and wore all the tips out on the rockers and bent two push rods
mjr46 is offline
Old 10-19-2007, 10:37 PM
OnyxCobra
OnyxCobra's Avatar
I torqued all mine down to a specific torque. I know you tighten them to zero lash and then they have to reach the specific torque between 1/4 and 1 full turn of the wrench. Here's a link: http://www.corral.net/forums/showthr...ght=crane+2030
OnyxCobra is offline
Old 10-20-2007, 06:54 AM
Joel5.0
Joel5.0's Avatar
ORIGINAL: andywear87
Did you check valve train geometry and determined the correct pushrod length your setup requires?...... this is key to obtain the right preload on the lifters + it's not a " that setup uses a x.xxx length pushrod" type of deal ..... you have to measure it and set it.
Joel5.0 is offline
Old 10-20-2007, 10:09 AM
andywear87
andywear87's Avatar
it was a setup that was put together buy a race shop in my area that specializes in 5.0s when i changed my cam i went with new rr's and pushrods
Old 10-20-2007, 11:52 AM
67mustang302
67mustang302's Avatar
Some roller rockers are just noisy too. When my car's idling with the hood open it almost sounds like a diesel sometimes [>:]
67mustang302 is offline
Old 10-20-2007, 12:01 PM
mjr46
mjr46's Avatar
what brand roller rocker do you have?? and how did you determine the right length push rod???
mjr46 is offline
Old 10-20-2007, 03:04 PM
OnyxCobra
OnyxCobra's Avatar
You use a pushrod length checker, here's some info, read both:
http://www.mustangcentral.net/tech/geometry.html
http://www.compcams.com/information/Products/Pushrods/
cr620
10-03-2022 10:18 PM
Sixer4Life
10-12-2015 04:26 AM
UrS4
10-03-2015 06:23 AM
winner99
09-30-2015 07:04 PM
Sixer4Life
09-28-2015 07:05 AM
Quick Reply: adjusting pedistal rockers
