Throttle Body Cleaner
Old 10-20-2007, 11:08 AM
ponyboy88
ponyboy88's Avatar
Default Throttle Body Cleaner
looking to clean the iac on my 5.0 mustang and on the 5.0 bronco i just brought for my g/f, says i should use throttle body cleaner to clean it, is this the same as carb cleaner or what, where do i find it?
ponyboy88 is offline
Old 10-20-2007, 11:15 AM
92Rideagain
92Rideagain's Avatar
Default RE: Throttle Body Cleaner
Ford has a throttle body cleaner and you should be able to find one in your local auto parts store. It is going to smoke like hell for a minutes, so do it outside.
92Rideagain is offline
Old 10-20-2007, 11:28 AM
93 LX FiveO
93 LX FiveO's Avatar
when i first did it to my car it caused a backfire through the intake.. a small one but enough to make me jump
watch where u stand lol
93 LX FiveO is offline
Old 10-20-2007, 11:33 AM
ponyboy88
ponyboy88's Avatar
thanks
Old 10-20-2007, 11:35 AM
ponyboy88
ponyboy88's Avatar
hopefully this solves my idle problem in both cars, how much does it cost on avereage to convert dense air to maf and is it going to be a problem that the bronco has two air runners into the intake from the air box
Old 10-20-2007, 11:49 AM
92Rideagain
Go through the junk yard and find a MAF that is calibrated for your injectors and swap the computer and you are good to go for cheap.
Old 10-20-2007, 03:13 PM
89TripleWhite
89TripleWhite's Avatar
yah i think STP has a good throttle body/intake cleaner, its like 3.99 and it smooths out the idle. alost try cleaning the idle air control
89TripleWhite is offline
Old 10-20-2007, 06:28 PM
Lordy
Lordy's Avatar
DONT use carb cleaner. It has solvents in it that Injector cleaner does not and can dissolve plastic parts in the fuel system. Seafoam might be a possiblility.
Lordy is offline
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
guitarman376
09-30-2015 05:54 PM
GLOCKer
09-28-2015 07:36 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: Throttle Body Cleaner
