Where is the ECT sensor and TPS sensor located?
RE: Where is the ECT sensor and TPS sensor located?
Here you go......
For the ECT and ACT..... you want to place a jumper pin/wire between the connector pins and run a KOEO.... if the codes switch to 61 (shorted ECT) and 64 (shorted ACT)..... replace the sensors, otherwise you have a wiring problem that needs to be traced.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
