Mass Air Flow Sensor
Old 11-03-2007, 09:08 PM
mustangsho
mustangsho's Avatar
Default Mass Air Flow Sensor
Does any one know anything about changing the air fuel ratio by rotating the maf?
mustangsho is offline
Old 11-03-2007, 09:12 PM
91hatchgt
91hatchgt's Avatar
Default RE: Mass Air Flow Sensor
What do you want to know? It is called "clocking" the MAF. Might search that.
91hatchgt is offline
Old 11-03-2007, 09:17 PM
mustangsho
mustangsho's Avatar
I have heard all about it. My car is runing to lean and someone told me to rotate the maf. my fuel pressure is good.
Old 11-03-2007, 09:24 PM
91hatchgt
91hatchgt's Avatar
Well, if your fuel pressure is good, and your fuel pump isn't going out, and your injectors are clean, your MAF is clean, and your air filter itself is clean, then you might try rotating the MAF clockwise a little bit to make it run fatter.
When I owned the car, (before the injectors were upgraded) my tuner clocked the MAF just slightly to keep it from leaning out. It barely does anything, but it did help some. Here's a photo, it is clocked just slightly.
Old 11-03-2007, 09:34 PM
mustangsho
mustangsho's Avatar
Cool well i had the wideband on it today and it was at about 13.5 a/fwot. Do you think i can richen it up a enough by doing it???
Old 11-03-2007, 09:36 PM
mustangsho
mustangsho's Avatar
The air filter is brand new. The pump pressure is perfect and the amperage pattern is good, and i cleaned the maf today, and the injectors are fairly new
Old 11-03-2007, 09:37 PM
91hatchgt
91hatchgt's Avatar
I don't know, but it doesn't hurt to try. Might try buying a Fuel pressure regulator. They are cheap, bolt right on and you can turn up the fuel pressure with the turn of one screw. They are key to tuning the fuel system just right. Pretty cheap, they can be had for about $70.
Jb145700
08-21-2022 06:37 AM
1996cobraconvertible
SVT Forums
13
01-07-2016 04:50 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
TfcCDR
09-14-2015 12:08 PM
uedlose
09-10-2015 03:30 PM
Quick Reply: Mass Air Flow Sensor
