oil pressure help
oil pressure help
hey guys, recently done h/c/i and am still working out some of the bugs and what not. The other day i was on the free way cruisin about 75-85 in 5th(t-5) and i looked down at my oil pressure gauge and it was reading super low... like the first notch or so on the stock gauge 10 psi?, so i let off the throttle and it climbs back up to reg pressure which is about the middle of the gauge 40-50 psi. When the car is idling the pressure is fine, it only does this when im giving it throttle or cruising around that speed in 5th. I'm going to get a new oil pressure sending unit soon to see if that fixes it.
Also ive noticed that ive got a small oil leak coming from the drivers side of the engine, when i did my h/c/i the dipstick tube broke so i replaced it with a ford racing one, put black permatex on it and whatnot, but ive been under the car trying to find the source of the leak and i cant rly find it. The oil is dripping down the bellhousing to the bottom and seems to only be coming from the driver side of the bellhousing. I checked my v/c gaskets and all that but its not coming from up top its somewere down by the dipstick tube or possibly the rear main? any suggestions?
RE: oil pressure help
ORIGINAL: aode06
die and a black light ftw
ccdguy
09-19-2015 05:20 PM
